Not able to add value to custom field list in python jira
sohny.pulikien November 26, 2019 edited
I have custom field which takes a list of users , I am not able to update it with new values using jira python script. Please find below the method i have used
-> testuser = jira.user('rtracy')
(Pdb)
> /u/cm/sandbox/createG2jira_test.py(50)create_G2()
-> G2_issue.fields.customfield_14904.append(testuser)
(Pdb) testlist = G2_issue.fields.customfield_14904
(Pdb) p testlist
[<JIRA User: displayName='Jai Dembla', key='jdembla', name='jdembla'>, <JIRA User: displayName='Ramesh Babu Nidadavolu', key='rbabu', name='rbabu'>, <JIRA User: displayName='Rick Stoneking', key='rstoneking', name='rstoneking'>, <JIRA User: displayName='Vakil Arora', key='varora1', name='varora1'>]
(Pdb) testlist.append(testuser)
(Pdb) p testlist
[<JIRA User: displayName='Jai Dembla', key='jdembla', name='jdembla'>, <JIRA User: displayName='Ramesh Babu Nidadavolu', key='rbabu', name='rbabu'>, <JIRA User: displayName='Rick Stoneking', key='rstoneking', name='rstoneking'>, <JIRA User: displayName='Vakil Arora', key='varora1', name='varora1'>, <JIRA User: displayName='Robert Tracy', key='rtracy', name='rtracy'>]
(Pdb) G2_issue.update(fields={'customfield_14904': testlist } )
*** TypeError: Object of type 'User' is not JSON serializable
I am not sure what I am doing wrong
Gonchik Tsymzhitov
Hi!
the method expect to have a list of usernames instead the list of User Objects
Teja
May 12, 2021
@sohny.pulikien
Did you get it resolved?
sohny.pulikien May 12, 2021
Yes I was able to resolve it as mentioned above by Gonchik. code snippet below:
issue.update( {"customfield_14904":[{"name" : "spolakoen"},{"name" : "rtrimbed"}]})
Teja
May 12, 2021
@sohny.pulikien
I was trying to append user to the list without disrupting existing users in the list.
Same like your code
for issue in jira.search_issues('project = "xyz" and issuetype = Epic and status not in (Closed) and Testers in (rkapoor)', maxResults=100):
print('{}: {}'.format(issue.key, issue.fields.customfield_10600))
testuser = jira.user('rkapoor1')
testlist = issue.fields.customfield_10600
testlist1 = ','.join([str(i) for i in testlist])
print(testlist1) //to check in console
issue.update(fields={"customfield_10600": testlist1})
It does not work at all.
You are again doing the same mistake which i did, ur taking an object of username... i suggest u directly pass the name string .
Ex:  the line
is the culprit. this will give u an object which is not useful.  instead pass the name string rkapoor to name feild as is
issue.update(fields={"customfield_10600": [{"name" : "rkapoor1"}]}
Teja
May 12, 2021
Actually, this code replaces all the user with "rkapoor1".
Just wanted to append "rkapoor1", when JQL finds "rkapoor" in the Testers field (the Testers field might contain other users as well
SS:
Ah that makes it easier, read the values from the field, assign it to a variable and then assign it back including new values appended in the list
Teja
May 12, 2021 edited
@sohny.pulikien
I am new to this jira-python.
Can you please help me the code.
sohny.pulikien May 21, 2021
I would suggest u can google on how to assign values to list in python and from there use the above functions that's mentioned above
