Sign up Log in
Not able to see worklog date after exporting the issues in excel
Farahath Bujaruk November 29, 2015
When I export the issues in excel, not able to see worklog date field after exporting.
Please suggest me, what can i do to see that field in excel after exporting from jira.
Midori
March 23, 2016
As Nic pointed out, there can any number of worklogs per issue, and the built-in Excel export feature will not export those.
The Better Excel Plugin will. Its export templates are totally configurable for this, but there are two pre-created templates for these use cases:
  1. Export all columns currently visible in the Issue Navigator plus the worklogs
  2. Export all fields plus the worklogs
In case there are more than one worklog for an issue, those will create separate lines in the final worksheet.
Nic Brough -Adaptavist-
March 23, 2016
Is that Cloud enabled yet?
November 30, 2015
How are you getting the worklogs out in the sheet?  (Bearing in mind you can have many per issue)
