Not able to update "Security Level" field
Pushpkant Garg
I am trying to update the "Security Level" field based on the Team selected by the user.
Here is the code:
def issueKey = event.issue.key
def customFieldName = 'customfield_11048'
def result = get("/rest/api/2/issue/${issueKey}?fields=${customFieldName}")
.header('Content-Type', 'application/json')
.asObject(Map)
Map team = null
import org.apache.log4j.Level
import org.apache.log4j.Logger
def myLog = Logger.getLogger("com.onresolve.jira.groovy")
myLog.setLevel(Level.DEBUG)
if (result.status == 200) {
team = (Map)result.body.fields[customFieldName]
myLog.debug "team ......"+team.value
if(team.value == "Asia"){
def result1 = put("/rest/api/2/issue/${issueKey}")
.body([
fields: [
security : [
.asString()
if(team.value == "Africa"){
.body([
fields: [
security : [
.asString()
if(team.value == "Europe"){
.body([
fields: [
security : [
.asString()
if(team.value == "Iberoamerica"){
.body([
fields: [
security : [
.asString()
if(team.value == "ILS"){
.body([
fields: [
security : [
.asString()
if(team.value == "North America"){
.body([
fields: [
security : [
.asString()
if(team.value == "Repairs"){
.body([
fields: [
security : [
.asString()
if(team.value == "Russia"){
.body([
fields: [
security : [
name : "Russia and Azal"
.asString()
if(team.value == "Azal"){
.body([
fields: [
security : [
.asString()
myLog.debug "Team : "+team.value
Script is working fine but not updating the "Security Level" field.
Log Snippet.
2019-08-23 04:22:51.015 INFO - Serializing object into 'interface java.util.Map'
2019-08-23 04:22:52.036 INFO - GET /rest/api/2/issue/FB-5?fields=customfield_11048 asObject Request Duration: 4241ms
2019-08-23 04:22:52.058 DEBUG - team ......Russia
2019-08-23 04:22:52.630 WARN - PUT request to /rest/api/2/issue/FB-5 returned an error code: status: 400 - Bad Request
body: {"errorMessages":[],"errors":{"security":"Security level name 'Russia and Azal' is not valid"}}
2019-08-23 04:22:52.631 INFO - PUT /rest/api/2/issue/FB-5 asString Request Duration: 415ms
2019-08-23 04:22:52.632 DEBUG - Team : Russia
2019-08-23 04:22:52.633 INFO - Run script completed
I have got all the necessary permission.
Kindly help me where I am wrong.
Pushpkant Garg
User Executing the Transition was not part of the Security Level.
Andrew
August 22, 2019
Hi @Pushpkant Garg ,
I see:
Error happen only for that name or for any others?
B.R.
Pushpkant Garg
Hi @Andrew
I got the solution. I was not part of the Security Level. After adding myself to the Security Level, script works fine.
Like Andrew likes this
