Not able to use "IN" operator in summary field using rest api jql query
jay
We have summary field and it's details is below.
        "id": "summary",
        "key": "summary",
        "name": "Summary",
        "custom": false,
        "orderable": true,
        "navigable": true,
        "searchable": true,
        "clauseNames": [
            "summary"
        "schema": {
            "type": "string",
            "system": "summary"
I need to filter the summary field values using REST API JQL query .
The query is " Project = GHJ and summary IN("title1" , "title2")". But it is throwing the error.
    "errorMessages": [
        "The operator 'in' is not supported by the 'summary' field."
    "warningMessages": []
rest api : /rest/api/3/search
Manoj Gangwar
September 22, 2024
Hi @jay
Summary field support only ~ and  ! ~ operators.
You can use summary ~ text1 OR summary ~ text2
jay
@Manoj Gangwar  Thank you I will try this.
Like # people like this
Manoj Gangwar
September 23, 2024
If it resolved your issue, please accept the answer to mark it as resolved.
