Not all selected work items appearing in Plan
Jessica Jones September 8, 2025
I am playing around with the Plan view in Jira software for the first time and am noticing that the view is not including all expected work items in its views and charts.
I am using a filter as the work source for my Plan; this filter returns 716 work items, but in the Work Item source page of plan settings, shows as only returning 332 work items.
Filter view:
Work item source view:
I have the same permissions levels for all projects/work items in the filter, so I cannot fathom why this is happening and it is making all of the charts and analysis, which would otherwise be incredibly helpful, meaningless.
Does anyone have any suggestions? Thanks!
Trudy Claspill
Hello @Jessica Jones
Review the information in the Removed Work Items tab.
There is an option there, for instance, to remove items that have been completed/done for longer than a specified period of time. By default that is set to 30 days.
Trudy Claspill
Was your issue resolved with the information I provided?
If not, please let us know and we'll continue to try to help.
If your issue was resolved, please consider clicking on the Accept Answer button above my response so that your question will be marked as Solved.
Jessica Jones September 11, 2025
Hi @Trudy Claspill - thank you! This resolve my issue :)
Leigh Peevy
September 11, 2025
I am having this same issue.  After checking the age parameter as Trudy suggests above, I increased and it resolved the issue for me.   I would submit that there should be a # populated in the "0 Work Items" card to show the # excluded based on age so that it is much more obvious what is occurring.  Mine showed 0 like the examples above which is misleading.  Thanks!
