Not possible to move subtask to another status
Carmen Rosa Ussi October 4, 2019 edited
I am getting crazy as I am not able to solve a problem in my Jira dashboard, so I hope someone will be able to help me.
From previous days, team is not able to move subtasks to another status and I already checked everything.
1. Error message when moving ticket from status 'POR HACER' to 'EN PROGRESO' directly on the board.
2. Message when moving directly changing status inside the ticket.
3. At this point, maybe someone modified my role? No. Still Jira administrator.
4. Check transition contidions.
5. Compare transition conditions with what I already have in the ticket.
* Ticket is not flagged, so 'Flagged' does not have 'Impediment' value.
* I belong to jira-administrators team.
* Labels does not have 'pruebas_produccion' label, just 'etiqueta' label as a test to assure the problem was not the lack of labels.
6. Anyway, I tried removing all transition conditions. Same error message when trying to transit the ticket.
7. Maybe the problem is a mandatory parameter? No mandatory parameters as I already checked too.
Then, another idea about what is going on? Thank you in advance.
Carmen Rosa Ussi October 10, 2019
After a bit help of Atlassian support, I found out what the problem was.
Checking post-functions when a new subtask is created, I found that there was a function for a attribute that did not exist anymore, so I remove it and subtasks workflow is working fine.
I hope this clarification will help to anyone with same Jira problems.
Best regards.
Vickey Palzor Lepcha
October 4, 2019
Did you verify your issuetype schemes ?
Is your issuetype subtask following the same scheme as all other issuetypes in your project ?
Thank you for the quick and first answer.
Anyway I already checked it too. I took into account that for the changes I mentioned in the post.
Any other ideas? As I already check that it is not possible to access to log in Cloud version, I am actually blocked with this.
October 4, 2019
Carmen - if these are on Cloud, I'd advise you to get help from Atlassian.
Like • Carmen Rosa Ussi likes this
Learn more
