It seems that suddenly we are not getting any notification emails. This includes ticket creation, updates, and closures. I've used the "Send email" tool to send an test email to a group and this works fine but nothing else seems to be working.
I have not W have not changed the default notification scheme lately, and it is still applied to all of our projects.
If I knew of anything else to check or do i would, but at this point I'm just looking for a little direction.
Assuming the problem is not with the notification scheme, please check your profile settings (https://<hostname>/secure/ViewProfile.jspa), and under "Preferences" verify that the "My Changes" option is set to "Notify me".
Of course!! I had completely forgotten about that setting, and I kept testing with actions that only would have sent email to myself (didn't want to spam my coworkers). Thanks!
Have you looked at the Mail Queue to see if emails queued up?
https://yourjira.com/secure/admin/MailQueueAdmin!default.jspa
I have. The queue shows nothing there. I even did a "Flush" to make sure that the that, perhaps, the count was off but something may be stuck. No luck at all.
I have the same problem, not getting notification emails but my mail queue is empty.
I'm having the same issues, but it's inconsistant. Some emails appear to send, such as the test, but others don't, even though the workflow and notification schemes have not changed.
Hi Dan, you could check the solution that was given in this other answer. It was about the same problem.
Sadly that is not it. We've had these projects set up for months and have been receiving emails, until recently. The default notification scheme has been unedited and added each project but we are not getting emails any longer
Have you tried to send the test mail?
In the section where you can see the Mail Queue there's a tab called 'Send Email' where you can send a mail to the users. This is often used like a 'Test Mail', is there where you send the mail you indicated?
Good news, at least we know it isn't a Jira server problem. Now, it could be two things I think.
One, maybe there was a change in the notification scheme that you weren't aware of.
Two, maybe there were changes on the Workflow. You could check if you are using the same workflow and workflow scheme as always. If no one changed that you could check inside the workflow you are using if there were changes on any 'Event fire' on the Post-Functions of the transitions.
I seem to be experiencing the same problem with Atlassian OnDemand. I've tried with the default notification scheme, and also with a simple notification scheme which does nothing but email the reporter when an issue is created. I've checked our spam filtering (using google apps + postini), and no messages are getting caught there.
