Notification on linked issue update
Vassili Gorbenko November 23, 2018
Is there any way to get notification if linked issue (not sub-task) changed its status?
Tom Lister
Hi @Vassili Gorbenko
when an issue changes status by workflow action an event is fired. You can configure who gets that event in the notification schema.
https://confluence.atlassian.com/adminjiraserver073/creating-a-notification-scheme-861253478.html
you can use custom events in a workflow to refine the configuration
plugins like scriptrunner can allow you  to conditionally fire custom events
Vassili Gorbenko November 25, 2018
Hi @Tom Lister, will it work for case when issue A status changed and linked issue B assignee will receive notification about issue A status change? Speaking in a business requirements language issue B assignee have no relation to issue A and don't knowanything about it, but need to stat work on issue B, when issue A is closed.
Tom Lister
I would use scriptrunner or similar to achieve this.
Write a groovy post function that will be processed when the issue A status is changed. Post function will go through the links to issue B's and make a transition on issue B which will fire a notification. You can create a link type with a name  you will specifically use to identify all links being processed or some other criteria.
Thanks! Will try.
Thomas Hansen
April 30, 2019
Did you succeed in doing this?
I need the same functionality.
Best,
Thomas
a.elali.ast
January 20, 2020
Hi there,
@Thomas Hansen @Vassili Gorbenko I am interested in this functionality as well!
Any news on that?
Thanks in advance!
Ahmad
