Notification schemes broken
Deleted user October 27, 2021
In our project we firstly decided to quit the notification scheme but now we can't add another one because the screen stays blank like this:
Andreas October 28, 2021
Hello, I just created the same error in my project.
We switched in the Project Settings -> Notifications -> The notification scheme to "None".
And after you switch it, you dont have the option to switch back to another. The whole right frame stays blank like in the screenshot from Pablo Gamarro Lozano.
And if you try to solve it from the other direction: You can create a new "Notification scheme", but there is no option to assign this to a Project.
BR
Suvradip Paul
October 27, 2021
Hi @[deleted] ,
Thanks for posting.
Could you please check this guide and try to add a notification scheme -
https://support.atlassian.com/jira-cloud-administration/docs/configure-notification-schemes/ ?
Let me know  if you're still facing an issue.
Daria Borisov
October 28, 2021
Hi @Suvradip Paul ,
Unfortunately the guide doesn't help solve the problem. I have the same issue - I can create/edit Notification Schemes, but I can't associate it with my project because the settings page for notifications is blank.
Suvradip Paul
October 28, 2021
Thanks @[deleted]  for responding. I shared the last guide also for the section - Associating a notification with a project or board. Are you facing the above issue while following that to associate?
