×I am trying to auto populate a number field from a custom text field on transition using automation.
I have a custom text field that holds a hexadecimal value, which I would like to convert to decimal value and populate that in to a number field when transitioning the state from any-state to "done".
I am able to read the string from the custom-text field using automation but am unable to change the format to decimal
tried using field.asNumber.format option, but its not working (changes value to None)
Example value in text field - 0xA
Expected value in number field - 10
How can I achieve this during the automation?
Hi @sreeram.anikodemahadevan -- Welcome to the Atlassian Community!
You may force the conversion by adding the hexadecimal value to 0 in a math expression, like this:
{{#=}}0+{{issue.MyHexField}}{{/}}
@Bill Sheboy how do we do the other way around as well?
I doing a math on the HEX field and writing to another field. The resulting number always ends up in decimal.
How do I convert the decimal to hex?
I was not able to find support for that in automation rules, such as with the format() function.
So that would be a no go then.
Any other thoughts on converting an integer to hexadecimal?
Before doing this, my question would be: what problem is this solving?
Some workarounds I can think of are:
I have a list of stories with requests for getting assigned with a sequentially progressing hexadecimal number.
When the issue get approved I would like the automation to look at the last assigned hex number increment it by '1' and update the issue which got approved.
