Numerical Comparison against Assets Schema Attribute
Benjamin Leidner
May 16, 2024 edited
I'm totally stuck and hoping someone here can help me.
A user fills in a custom field in a Jira screen named "Total Contract Cost" (number field)
I have all my users in Assets in my "Max_Spend" schema.  This has the attributes "Name", "Email" (etc.) and "Purchase Approval Limit"
I need an automation to compare the value in the field against the value in Assets to determine if the employee is allowed to spend that amount, and provide a deny message if
"Total Contract Cost" > "Purchase Approval Limit."
Any experts have a solution?  Thanks so much!
-Ben
Mikael Sandberg
May 16, 2024
You can do the compare using smart values and numerical compare, in your case it would look something like this:
{{#=}}{{issue.Contract Cost.lte({{object.Purchase Approval Limit}}){{/}}
This would return true if the cost is equal or lower than the limit.
Benjamin Leidner
Thank you so much for this!  But where/how do I enter this logic?
In my automation, I have:
When: Issue created--
Then: Lookup Objects in MAX_Spend [Schema]
Query: objecttype = "NS_Employee_Spend" and "Name" IN ("{{issue.customfield_10073.join("\",\"")}}")
So I grab the "Purchase_Approval_Limit" from Assets but where do I put the comparison logic so it prevents the transition and throws the appropriate error message?
Thanks so much.
-Ben
Benjamin Leidner
Benjamin Leidner
Mikael Sandberg
May 17, 2024
You have two options, one is to create a new smart value and then use the IF condition to see if the smart value is true of false. The other option is to use the IF condition and compare the two values using the smart value compare. The issue with this is that you cannot use <=, it only has less then.
Benjamin Leidner
Got it, thank you!  And with a nice transition screen, too.
Like • Mikael Sandberg likes this
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
