I have an existing filter that ends with ORDER BY "Business Rank" ASC, KEY DESC.
The filter worked fine until 2 weeks ago. Now it completely disregards the "Business Rank" ASC and only sorts by KEY DESC.
Anyone else having recent issues sorting by custom fields?
Ron
@Ronald Sochocki, so if you are in filter list view and have the Business Rank filed displayed can you click on the heading to filter ASC/DESC?
@Jack Brickey Yes I can click on the field and it shows up/down arrow to indicate column is sorted. However, there is no change in the results.
See snippet below. WW-34 and WW-27 should be sorted to the top based on their "Business Rank".
