Old kanban projects
Lubna Dabash March 4, 2022
I have some company managed kanban project (old board view, no backlog etc.)
whenever i try to create a company managed project it sync the old one while if i create a team managed kanban project it shows the new kanban
my question is how can i change the old kanban projects for the company managed projects ?
Lubna Dabash March 5, 2022
what i me by synced is that any company managed project will have the same old kanban. view plus the same workflow,
wanted to ask about how i can get the new kanban view for them ?
old view :
Screen Shot 2022-03-06 at 9.43.44 AM.png Screen Shot 2022-03-06 at 9.43.56 AM.png
new view :
Screen Shot 2022-03-06 at 9.43.08 AM.png Screen Shot 2022-03-06 at 9.43.15 AM.png
Ollie Guan
Hi @Lubna Dabash ,
Company-managed Projects created by the system administrator.
Each Project has a default template. After the Project created, the system administrator can adjust the workflow and board settings.
Sachin Dhamale
Hi @Lubna Dabash ,
If your jira is connected with other tool then it will synch those data to your newly created project if you select the synch check box while creating project.
Can you elaborate more on this what you need to do? you don't want to synch the data?
Ollie Guan
Hi @Lubna Dabash ,
Sync means Issues are synced or something else?
