On Advanced Roadmaps, can a 'Read / View Only' viewer have access to filter the plan view?
Fahim Ahmed
On Advanced Roadmaps, if there is a 'Read Only' Plan, can someone with View / Read only access have the ability to filter the plan view so as to filter the view etc or is it fully locked down?
Walter Buggenhout
Hi @Fahim Ahmed,
Have you tried? As an admin, I am usually not in the situation to try this myself, but filtering a view is not something that would impact the data in it. So I would expect a read only user of a plan to be able to filter the view indeed.
See advanced roadmaps permission documentation for an overview of the different roles and what they can do. While your specific question is not detailed out there, you can get a good feel about the most impactful things each role can or cannot do before you try it out.
Hope this helps!
Fahim Ahmed
Thanks Walter. I've done some testing and yes, the filters can be used to view different cuts of the information, but can't be edited.
