On my Jira board I want to build swimlane using type assignee and queries.
At the moment its an either or condition that has been provided. My requirement is to use a query to be my 1st swimlane. and then use the assignee to further create the swimlanes.
Hi @Roopali Singh,
Unfortunately you can't do that. My suggest to your situation would be build everything on Queries but it can get a little too manual if you have a lot of swimlanes you want to have.
Nguyen
Thanks for the reply @Nguyen Tran
Yeah with queries it will get into manual maintenance which is what I wanted to avoid. But if there is no other option then nothing else can be done about it.
Thanks again
@Roopali Singh Glad I could help. Good luck!
