Only show sprints in this project
JZD
Hello
Just wanna ask if someone has a solution for our problem
Enabling the: Only show sprints in this project
Is resulting in showing not one sprint.
I checked already:
"Only show sprints in this project" not working as expected in Jira Cloud | Jira and Jira Service Management | Atlassian Support
The settings in our project are looking fine for the location
and
How to limit the Sprint field to only show active or future sprints in the current project | Jira and Jira Service Management | Atlassian Support
but the problem cant be solved. Anyone have some idea what to look into it to solve this?
Thank you in advance
Prachi Bolar
April 2, 2025
Welcome to community :)
Please check this feature requests to understand more on the same : https://jira.atlassian.com/browse/JRACLOUD-91042
This could one of the reason no sprints showing
Thank You,
Prachi
JZD
Hello
Thank you for your answer, will take a look into it. This could be the reason.
Prachi Bolar
April 3, 2025
Thank you :) If still it's not working please reach out to support : https://support.atlassian.com/contact/#/
team can gain access and check this directly
David Nickell
April 2, 2025
if your sprint name is the same in two different projects, you will encouter weirdness like this.
Use Sprint Names that are disctinct by projects.
JZD
Hello David, thank you for your answer. Our sprint name is only assigned to our project and unique in the name. But good to know.
So how you propose, our sprint name is the same how the project name and it exists only once.
David Nickell
April 3, 2025
@JZD  - Try running this REST Endpoint in a browser:  /rest/agile/1.0/board.
It should give you all the boards in your instance.  (Projects --> Boards ---> Sprints).  Be sure the board your sprint is associated to is located with your project.
