Oracle DB Compatibility issues with JIRA 7.13.
BrahmaReddy Seelam - Consultant December 16, 2018
we are using jira vesrion 7.6 with db version oracle 12.1.0.2.0(JDBC driver version 12.2.0.1.0) . Planing to upgrade JIRA to 7.13 .
will there be any compatibility issues with the current db version ?
Please suggest
Johan Soetens _Dumblefy_
December 17, 2018
When upgrading you should review the upgrade notes of all relevant versions, in this case 7.7.x until 7.13.x
Jira Software release notes
Oracle 12c1 should be okay but best practise is to always check it :-)
BrahmaReddy Seelam - Consultant December 17, 2018
Thanks for the prompt reply @Johan Soetens _Dumblefy_,
which file we have to configure the jdbc and where do we mention the jdbc driver version ?
December 18, 2018
JIRA needs a database driver to connect to your database. The driver is in a file with the '.jar' suffix, it needs to be copied to the  <JIRA installation directory>/lib/ directory.
You can find the Oracle JDBC drivers here.
Please review the Supported platforms documentation, for Jira 7.13 you'll see that Oracle 12c R1 is supported and you can use the 12.2.0.1 driver.
ARBES Technologies, a.s.
May 30, 2019
It is ok, but i found some errors, you should patch the database ORACLE to the last patch (now May 2019)
