Order of fields in scrum screen
Jade Melcher
How do you edit the order of fields on a scrum screen for a project?
Petter Gonçalves
September 5, 2018 edited
Hello Jade,
Are you meaning the fields on the cards of the Board or in the issue detail view that appears when you click on an issue?
If you are meaning the issue detail view, are you talking about the order of fields in the Old detail view (Appears in the right side) or in the new detail view (Pop-up window)?
Respectively, the order of the fields can be changed by clicking on the three dots icon (...) > Board settings > Card layout and Issue Detail View, however, the detail view cannot be changed if you are using the new interface (Pop-Up window), so you must follow the instructions in the documentation below to enable the old view again and enable the customization:
The new JIRA issue view
Jade Melcher
Thank you! I was referring to the new detail view and it looks like they are still working on the feature. Thanks for your help!! For now I edited the EDIT and CREATE views :)
Register now
