While looking for unused custom fields in the database I have found some really old customfields:
Test Sessions | 10008 | com.atlassian.bonfire.plugin:bonfire-multi-session-cft |
Testing Status | 10017 | com.atlassian.bonfire.plugin:bonfire-testing-status-cft |
Bonfire Browser | 10011 | com.atlassian.bonfire.plugin:bonfire-text |
Bonfire Operating System | 10012 | com.atlassian.bonfire.plugin:bonfire-text |
Bonfire User Agent | 10010 | com.atlassian.bonfire.plugin:bonfire-text |
issueFunction | 10402 | com.onresolve.jira.groovy.groovyrunner:jqlFunctionsCustomFieldType |
Bonfire jQuery Version | 10015 | com.atlassian.bonfire.plugin:bonfire-text |
Bonfire URL | 10013 | com.atlassian.bonfire.plugin:bonfire-text |
Bonfire Screen Resolution | 10014 | com.atlassian.bonfire.plugin:bonfire-text |
uuid | 10018 | com.atlassian.jconnect.jconnect-plugin:uuid |
Those fields are not displayed on custom field list in Jira. When I try referencing the field by the ID jira shows:
There are no customfieldvalue entries for these fields in the database.
Plugins/Apps that probably introduced those fields (Bonfire, Script Runner, jconnect) are long gone from our instance. I suppose old versions of these plugins were unable to properly clean after themselves while uninstalling, and those old fields were carried over with all our subsequent jira upgrades.
Integrity Checker shows that everything is fine - obviously it can't detect those fields.
How can I clean those orhpaned unused customfields without breaking anything? Is there any tool for this? Or maybe some KB article on this?
It is safer to simply ignore them, although if you put scriptrunner back, you could write a script to safely remove most of them.
Why are you worried about getting rid of them?
Well, we do ignore those so far, but they pop-up from time to time in different scenarios and force us to keep track of them as an exception to the rule. Few cases are:
So far it's only annoyance and unnecessary maintenance cost but I generaly like to tie all loose ends to avoid the butterfly effect in the future, and these bugged entries definitely count as loose ends.
Yep, the cPrime Health Report is not coded to ignore them (I'd argue rightly so, as it's worth noting they are there).
As for DB Based Jira integrations, you probably shouldn't be doing that. Reporting directly off a Jira database is a terrible thing to do. One of the minor reasons is that it doesn't understand the logic for fields like these, so they don't know to ignore them.
