Hello guys,
I would like to ask you if you can help me out with my problem.
I wanna do pop-up window dialog, WHEN:
I'm on issue and wanna click on any button.
LIKE for example: We've got plugin email this issue, and i wanna do pop up window when someone will click on the button "Email", "Export" or "Share"
Are you sure you want send this issue via email?
Are you sure you wanna print this Issue?
Are you sure you wanna export this issue?
Are you sure you wanna share it?
Text doesnt matter, what I wanna know is how to do it.
We are using for example behaviours, scriptrunner, some automations etc.
Thank you a lot with helping me out!
I'm up for any informations you would need to help me.
I'm new at it and it can be for someone really easy, but I can't get it.
Thanks in advance,
Chozo
