Parallel Permission
kA
Hi Friends,
I have enabled the "Parallel sprint" options from JIRA lab and created the two sprint and work on it. May i know whether any data loss(JIRA task details) occurs, incase if they don't want to implement the feature.
Thanks in advance,
Karthik.
Nic Brough -Adaptavist-
December 22, 2014
There might be.  There's no way of knowing at this point.
I imagine that if this feature is accepted into the core, then you won't lose anything.  Although it's entirely possible that there might not be a migration path, so you might lose the existing sprint data.
I cannot imagine why any scenario would lose you any data on issues.  I suspect the only exception might be for sprint data.  I could see a problem if you have some parallel sprints and the process can't handle it, it may simply pick the latest open sprint and close the rest, or even delete thm.
