PassIng the URL of the current issue via comment using Post Function (Comment Related Issues PF)
Fabio Vintorin June 18, 2024
How could I pass the URL of the current issue via comment using this Post Function? Example, if I want to pass the person responsible, I use currentUser.name
Bo Zhao
June 18, 2024
Hi @Fabio Vintorin
The format of the Jira issue URL is always going to be like:
https://<your-domain>.atlassian.net/browse/<issueKey>
 You can pre-fill the domain if it is always the same and get the Issue key using the variable.
Bo
Fabio Vintorin June 19, 2024
TKS !!
I'm going through this entire comment, what would it look like including the URL?
currentUser.name + ", solicitou aprovação e comentou: " + "\n" + transientVars.comment + "https://jira.sinqia.com.br/browse/<issueKey>"
Chisato Saito
Hi
How was this problems so far?
I'm looking for the way to add next issue via comments by automation rule.
I did it by Manually trigger. However I can't by automation trigger like status transaction.
FREE
