Performance of linkedIssuesOfAllRecursive
Hailin Zhang
Hi there,
We are facing a performance issue when using linkedIssuesOfAllRecursive in JQL
Below search runs for about 15 seconds to get result:
project = DATASVCENG AND issueFunction in linkedIssuesOfAllRecursive("issue = DATASVCENG-461") ORDER BY Rank ASC
While the other one only needs 2 seconds.
project = "Data Enablement - Stream" AND issueFunction in linkedIssuesOfAllRecursive("issue = DATAENB-19") ORDER BY Rank ASC
Can you please advise what causes the difference of performance?
Our jira environment details are as below:
Jira Software 8.13.19 (Data center)
JIRA Service Desk 4.13.19
Adaptavist ScriptRunner for JIRA 6.39.0 SEN-25066704
Regards
Hailin
Dam
July 18, 2022 edited
Hi @Hailin Zhang
It depends on the number of related issues to each search... If an issue has only 4 recursive links then the search can be quite fast, but if an issue has more than 100 recursive links, then the search can take few seconds.
Like mentioned in Scriptrunner doc: https://scriptrunner.adaptavist.com/5.5.8/jira/jql-functions.html#_linkedissuesofrecursive
If you have 1000s of indirectly linked issues, traversal of all of the links will take a few seconds.
You can use the function linkedIssuesOfRecursiveLimited to limit the depth of traversals along issue links so that the search can be more efficient.
I hope this helps a bit.
Dam.
SERVER
Help us plant more trees
