Hi Team,
Good Morning.
I want to add smart checklist for JIRA stories. This checklist will have following items as a part of mandatory fields.
Issue Type
Summary
Priority
EPIC Link
Assignee
Sprint
Description
Acceptance Criteria
The reason why I want it to implement is ,every story creator should be aware that these are the basic mandatory fields that has to be updated . If any of these criteria is missing ,checklist should show the rating as 6/7.
So please let me know does this involve extra cost on the part of company and also can we add this smart checklist template in Jira.
Regards
Shaily
Hi Shaily, when you refer to “smart checklist for Jira” are you actually speaking of the addon?
If so, I’m unsure why the addon would be needed at all for your requirement at all. Jira provides a means of making fields required at Create (or any other transition) OOTB. I use the Fields required Validator in the workflow properties to achieve this. By doing so the reporter will not be able to create the issue without completing all required fields first.
Hi Jack, Thanks for prompt action.
I am looking for 2 fields - One is Smart checklist and other one is Definition of Done.
Coming to Smart checklist ,I feel your response is what exactly I was looking for but I would need your assistance on this part - I use the Fields required Validator in the workflow properties to achieve this. By doing so the reporter will not be able to create the issue without completing all required fields first.Could you please tell me how to proceed for this.
And the other one - Definition of Done ,I am looking for the below template to be added in JIRA so that creator follows all these steps.
Regards
Shaily
For the Validator...
regarding the checklist I don’t use that addon but would recommend you review their documentation. I actually use a different checklist addon. It sounds like you wish to ensure that all of those checklist items are marked as complete before the issue can be moved to Done. It should be pretty straightforward. I know it is in the addon I use.
Hi @Shaily_Jain !
In case you are using our Smart Checklist add-on, it does let you validate the checklist completion before an issue can be moved to any other state in the workflow. Please refer to this article for guidance.
Feel free to also write in to us at smartchecklist@railsware.com so we can help you out with the setup of your flow.
Alina
