Planning poker not working on scrum project?
Chris Mitchell
April 14, 2022
The team has a scrum/software project set up, but when clicking on the planning poker it is not loading as it says its not a scrum project.
I have looked into the settings of the project, but have not been able to resolve this issue/
Has anyone had this issue or know how to fix this issue?
April 14, 2022
Hi @Chris Mitchell -- Welcome to the Atlassian Community!
There is no built-in planning poker feature for Jira Cloud.
That screen grab appears to be this addon product from the marketplace: https://marketplace.atlassian.com/apps/1224759/agile-scrum-planning-poker-for-jira?hosting=cloud&tab=support
I am not using that tool, and I recommend you contact their support directly for assistance.  Also that is a "freemium" tool, so it is only free at 10 users or less.  Please take that into account when you contact their support.  Thanks!
Chris Mitchell
April 19, 2022
Thanks - I have reached out to internal IT support to try and resolve this issue.
Like • Bill Sheboy likes this
Matthieu Poupard -Klaxoon-
Hi @Chris Mitchell ,
While there are "Poker Planning" only apps, have you ever considered using a more versatile whiteboard for those sessions (and for the rest of your agile planning meetings)?
Collaborative whiteboard vendors (including us here at Klaxoon) have a lot of great templates which integrate with Jira.
Björn Brynjar - Smart Guess
April 14, 2022 edited
Another option you only need 3 minutes to install and get started is using a tool without limitations, such as Smart Guess for Planning Poker:
I am the founder of Smart Guess, and here is what customer said who switched from one of the most widely used apps on the market:
  • 'The most efficient app for asynchronous estimations'
Other customers say :
  • 'Lightweight,' 'intuitive,' and 'out of the way'
Notice the app works both for teams using async and normal Planning Poker.
A few facts you might find interesting:
  1. Works for all projects types
  2. All types of issues
  3. 1000s+ of stories are estimated / day
  4. Only one reported bug last year - was fixed within 3 hours
I hope this is helpful information, happy estimation ;)
