Please let me know when changes could be checked, Changes in flow – to both sides.
koteswararao
March 12, 2019
Please let me know when changes could be checked:
  • Changes in flow – to both sides
  • Example of query for stories
Just a comment: task is separate instance so if user story (with dependent tasks) – tasks will not be moved itself.
If you discovered here some changes - pleas let me know. For example if Azure devops it’s possible. Story is “parent” and tasks (that are child) are also moved with it. Btw Azure devops is also Agile.
Nic Brough -Adaptavist-
March 13, 2019
I am afraid your question does not make any sense.
You have not told us what the sides are, what you mean by flow, what stories and tasks are being moved or how.
