Plugin for sprint statistics
Chasovskikh Kirill
Hello!
I’m looking for a plugin that can provide statistics for my sprints, specifically:
  • Average/min/max sprint workload (SP allocated vs. sprint capacity)
  • Average/min/max number of issues per sprint
  • Sum of Story Points (SP) from a custom JQL query (e.g., sum of SP from Stories without a parent)
Could you recommend anything? Thank you in advance!
Alexey Pavlenko _App Developer_
Hi Kirill,
You can use the app I developed - Multi-team Metrics & Retrospective.
  • Average/min/max sprint workload (SP allocated vs. sprint capacity):
    • Allocated = Final Scope (Screenshot #1).
    • Sprint Capacity = Completed Scope (Screenshot #1). However, it's not true capacity as-is. In most cases, you need to adjust capacity manually (velocity of sprint(s) without vacations – (minus) vacations in the upcoming sprint). I can implement it for you pretty quickly if needed.
    • To see average/min/max - click on Y-Axis label 'Sprints' (Screenshot #2).
  • Average/min/max number of issues per sprint - for that you will need to create a new report since it's another X-Axis dimension and select 'Issue Count' as Measurement Unit (Y-Axis) in the settings.
  • Sum of Story Points (SP) from a custom JQL query (e.g., sum of SP from Stories without a parent) - you can generate any custom JQL metric - CustomMetric: Rob Compl. Scope is one of them (Screenshot #1).
Screenshot #1:
Screenshot #2:
Additionally you get quantifiable retrospectives and other features.
Best regards,
Alexey
Marlene Kegel - codefortynine
Hi @Chasovskikh Kirill
I am Marlene, product manager of Quick Filters for Jira Dashboards.
With our app, you can aggregate any Jira number field, including story points. In the screenshot below, the Quick Issue Statistics gadget is configured to display work item count, time estimated, and time spent using the SUM function. You can also aggregate other time fields or Jira number fields using functions such as AVERAGE, MIN, and MAX.
Feel free to check out Quick Filters for Jira Dashbaords without installation on our demo dashboards.
Danut M _StonikByte_
Hi @Chasovskikh Kirill,
Definitely a good option for tracking all these sprint metrics easily & efficiently  is our Great Gadgets plugin. The app offers super-useful dashboard gadgets for trackie;cng these metrics.
For example, by using the Team Velocity gadget you can see the committed vs completed for every sprint, as well as min and max. The gadget can calculate by sum of story points, number of issues or any other estimation method.
For Sum of Story Points (SP) from a custom JQL query you can use the Issue Filter Formula gadget or the Advanced Issue Filter formula gadget offered by the same app, to calculate the value for the current or a past sprint :
or the Pivot Table & Pivot Chart gadget to get a chart like this for multiple sprints:
image.pngVery useful for you can be also the Pivot Table & Pivot Chart gadget, Sprint Burndown Burnup Chart gadget and Release Burndown Burnup Chart gadget. See more details here: https://community.atlassian.com/forums/App-Central-articles/9-gadgets-for-a-powerful-Scrum-dashboard-in-Jira/ba-p/1683063
If you have any questions, feel free to contact us at support@stonikbyte.com.
Danut.
Rahul_RVS
If you would be interested in a mktplace app for this requirement, pls do take a look at
Agile Velocity & Status Gadgets
The app comes with few dashboard gadgets to track team member's / team's velocity / productivity based on story points / time spent / issue count in a sprint  and also track sprint status with multiple parameters.
Disclaimer : I am part of the team which developed this app
Iryna Komarnitska_SaaSJet_
Although the app my team developed can't cover all your requests, it might still be helpful to you. Our team at SaaSJet developed the Time in Status app, which includes a Sprint Report that gives a visual breakdown of key sprint metrics.
The report provides insights into things like:
  • Committed vs. completed work (in Story Points, Original Time Estimates, or issue count)
  • Team velocity over the last 7 sprints
  • Workload distribution across assignees
  • Completion rates, carryover work, and scope changes
These sections can help you better understand sprint performance, team workload, and progress trends.
Eduardo Anflor - MindPro
Hi, @Chasovskikh Kirill
If you are open to a marketplace solution, I recommend Mindpro Insights. I work at Mindpro, and I believe it can help you with your use case. The app allows you to create agile dashboards easily (from a template or a blank screen) and share them with internal users via the customer portal.
The gadgets are interactive; if you click on one segment, the dashboard adapts to your filter, as well as the issues list at the bottom. Using your scenario as an example, I created a dashboard that uses the board filter. You can notice the Velocity Chart shows you the average points. With the "Sprint Progress" gadget, you can check the progress of all sprints in your board. You can also use the "Sprint Filter" to select just one sprint to show:
There are over 50+ gadgets you can select from, including custom gadgets.
I hope that helps.
Eduardo
