When attempting to upload a plugin "From my computer" the install spins for a long time. Sometimes I give up after ten minutes. Seems to affect both Confluence and JIRA.
If I attempt to upload a plugin from a URL I get this message:
Could not install the file http://host/data/software/jira/jira-misc-workflow-extensions-4.0.2.jar. Check that the file is valid.
(The file is valid according to jar -tvf filename
Pretty sure it is a client problem. I had success using a different PC at the office.
Hey Jason,
I see that the error attached is showing JIRA Misc workflow extensions where as screenshot shows Script runner plugin. Can you confirm where you are having trouble ?
In your dev environment,
Let me know how it goes.
Regards
Chander Inguva
