Portfolio for JIRA - How to see the "parent" ID/info in each hierarchy level?
Deleted user February 26, 2019
We are using the Portfolio plugin the plan our activities and build a better plan with context, scope and hierarchy levels.
It was defined the following hierarchy level: (5)
First 2 by Portfolio, and the following JIRA (Epics, tasks and subtasks)ScreenHunter_6148 Feb. 26 08.34.jpg
We want to see both information in the ticket about "parent" and "Sun" in each JIRA ticket view.
I the first Level, we can see the second one:
In the second and third hierarchy, we can see the "sun" but can not see the "father"
In the task view, we can see the father as "epic name" and the subtasks,
Similar, in Subtask view we can see the parent also.
What can we see the "parent" info in all cases? especially from epic to the second level defined by Portfolio?
Deleted user March 6, 2019
Found the solution
Thanks.
Mark Bednarski
Hi
Can you let me know how you solved it?
Thanks in advance
Mark
Deleted user July 19, 2019
The field was not in view screen.
just add it.
