JIRA Automation: Copy "Team" Field from Parent (Epic) when a new child issue (Task/Bug) is created
mark_liebold
I am trying to set up an automation that copies the value of the "team" field from the parent (Epic) when a new child issue (Task/Bug) is being created.
Even though the documentation about teams says that you can now use the "team" field in automation, this is not possible when it comes to the "Edit Issue" action, the field does not show up in the selection menu.
For the action "Field value changed" the "team" field is available, though.
I am grateful for any advice that will help set up the automation. Thank you!
3 accepted
Thuan, Do Dang
November 30, 2023
Hi @mark_liebold ,
You can try to update by Additional fields like below
"fields": {
"Team": "{{issue.parent.Team.id}}"
mark_liebold
Thank you for the help, it worked!
Margarita Turina
January 10, 2024
Hi!
Unfortunately this didn't work for me - it says "Additional fields contains invalid field(s) in 'update' or 'fields' section: Team" - but I definitely have the "original" Jira team field, not a custom one.
Could you guess what might went wrong?
Like Cindy Caranchini likes this
Ste Wright
January 14, 2024
Hi @Margarita Turina
Are you using the Custom Field's ID? Usually that's a more static option than the field name (just in case there's another Team field).
Otherwise, could you provide a screenshot of your Action?
Ste
Ste Wright
November 30, 2023
Hi @mark_liebold
You can use the Advanced section and JSON to do this.
For example, to modify an Epic's children when the value changes at an Epic level...
  • Trigger: Field Value Changed
    • Field to Monitor = Team
  • Condition: Issue Fields Condition
    • Field = Issue Type
    • Condition = equals
    • Value = Epic
  • Branch: Related Issues
    • Type = Children
      • Branch-Action: Edit Issue
        • More options...
          • Additional fields...
              "fields": {
              "customfield_10001" : "{{triggerissue.customfield_10001.id}}"
A few notes...
  • The Custom Field ID (i.e 10001) should match your Team field's ID
  • This is just an example rule, with example JSON. It might differ depending on how the rule is triggered (eg. if it's issue created, or parent being set at a story-level, the JSON could use a smart value which references the epic's team field in another way)
Let us know what you think!
Ste
mark_liebold
Thank you! I set up another automation where it was needed to change the "team" field in the children when it got modified in the parent and your advice helped me a lot.
Like Ste Wright likes this
Mayuresh Kamble
November 30, 2023
Hi @mark_liebold ,
Could you please try this in the edit issue action and let me know if it works
"fields": {
"team": "{{issue.epic.team.id}}"
Mayuresh
mark_liebold
Thank you for the help, it worked. However, I went with "parent" instead of "epic" in the JSON.
Josh
Is anyone aware of a feature request to make this important "team" field available as a field to edit in automation?
The workarounds above are very helpful, but an admin shouldn't have to go through all the hassle to do something like this.
August 8, 2024
Hi @Josh
There are several open suggestions related to adding the Team (and other missing fields) to the dropdown list for automation actions.  Here is one of them:
https://jira.atlassian.com/browse/AUTO-525
Like Josh likes this
Josh
Thank you, @Bill Sheboy
