We have a Jira Cloud Addon "At a Glance" DevOps Dashboard
We have been asked to add a version for Jira Server.
Did you have to recreate the plugin from scratch or are there easier options to port to the server API?
Any help will be greatly appreciated
Sean
You need to recreate it from scratch. The only thing you can do. You can put all logic in an external jar and then connect this jar to both of your plugins.
This would probably be better suited to the Development community -- http://community.developer.atlassian.com/
