  • Community
  • Q&A
  • Jira
  • Questions
  • Post Function to Auto Increment Custom Field on Jira Cloud on specific transition (not just status)
Kevin Christmann May 1, 2023
I need to increment a custom field by 1 on a post function. It is seemingly a simple ask, but I have some nuance that I cannot find an answer for.
I'm really struggling to figure out how to achieve this. I've read a dozen or so questions\replies related to this but none of them are exactly what I need. My assumption is that I need to use Scriptrunner to do this.
  • I use Jira cloud (other scripts I am seeing are for Server)
  • I need to do this on one specific transition. Note: this is not entering a specific status, but on a specific transition. I have more than one transition exiting and entering the exact same statuses, which is why I need this to be a post function and not automation. See screenshot below.
  • I was wondering if instead of Scriptruner, I can use the "Update Issue Custom Field" post function but it is not clear to me if I can make that value dynamic or if it is a static value.
Fabian Lim
Hi @Kevin Christmann
You can try using Jira Automation and add 1 to it everytime the transition is executed: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-math-expressions/
Fabian
Kevin Christmann May 2, 2023
@Fabian Lim  I don't think that works though because automation won't let me get as specific as I need. As I mentioned (and seen in screenshot) I have 2 transitions that both have the same starting and ending status. Automation does not let you specify a transition. It only lets you specify starting and ending status. (Unless I am overlooking something.)
Unless I am overlooking something, automation can only specify the from and to status. That doesn't work for me because I have 2 distinct transitions with the same "from" and "to". I need my automation to only apply to 1 of those. Which is why I think it needs to be a post function on the specific transition.
Karolina Dylewicz October 26, 2023
Hey @Kevin Christmann , you know how I did it:
on the transition where you want things to happen, I added a simple post-function to mark a custom field type select with just some value. I know this field doesn't change in any other situation.
Then, in the automation, I could use a trigger: when the field value changes to X, run through the action... :) and it works. Like this the system knows exactly when to do it :)
