Post Function to set due date from another filed plus 3 days
Jeff Meyer August 6, 2024
I have a project that auto creates additional tickets in other projects when a ticket is opened in project 1 (using post function "Create new issue"). I have been asked to set the "Due Date" field (in project 2) from the "Target End Date" field (in project 1) and add 72 hours or 3 days to it. I have been able to set the "Due Date" field (in project 2) to the "Target End Date" (from project 1), but not sure how to add the additional time  (72hrs or 3 days) to the "Due Date" field in project 2.
Jeff
Ramin Shanehsaz _Computerra_
Hi Jeff,
your post-function "Create new issue" has to come from an app that is installed in your Jira, since it is no standard Jira post-function. Can you tell us which one you are using, so we can help you with your problem?
Best,
Ramin
Jeff Meyer August 8, 2024
It looks to be from Jira Misc Workflow Extensions (JMWE)
Then, you can use the "Set new fields" functionality in the post-function to set the due date plus three days using the following Nunjucks expression:
{{ issue.fields["Target end"] | date('add' , 3 , 'days') | date("YYYY-MM-DD") }}
So it looks like this in your "Create issue(s)" post-function:
Let me know, if this works for you :)
Jeff Meyer August 9, 2024
Hi Ramin,
Thank you very much, that worked for what I was looking to do.
Thanks for taking the time to help me out with this.
Jeff
Like • Ramin Shanehsaz _Computerra_ likes this
John Funk
Hi Jeff - Welcome to the Atlassian Community!
Have you thought about using an automation rule instead of a post function in the workflow? Then it can be used more universally.
Jim Knepley - ReleaseTEAM
I think you're looking for the "Date plus unit" function.
...and not for nothing, you might add "BusinessDays" instead of just "days."  :-)
FREE
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
