Dear Jira community,
Our team is using time tracking in hours to define issues. The workflow is simple (open -> in progress -> done). When resolving the issue from status 'In Progress' to 'Done' we have a problem where Remaining Estimate value field stays with its value in the Done column and therefore affects reports (especially Resources in BigPicture). How can we make it to automatically set this value to 0?
We have tried to edit the workflow set for the specific project and define the transition line (the one from In Progress to Done) by setting the Post Functions. The exact function says: 'The Remaining Estimate of the issue will be cleared.' and it is set as no. 1 priority. Still, the Remaining Estimate doesn't get cleared.
Detailed use case:
Did you follow the same instruction in https://confluence.atlassian.com/jirakb/set-remaining-estimate-to-0-on-post-function-304579031.html
Could you place it at the top of the list of post functions?
Yes, the setup was pretty straightforward. The only thing I didn't notice that all the changes you make are only draft and start working after you publish the changes.
For some reason, the answer I posted to myself isn't here anymore, so once more:
I resolved the problem by publishing a draft of the edited worklflow. It is not enough to only make changes and close the editing of workflow.
@Fazila Ashraf Thank you for your help. I will anyway accept your answer so any future users may refer to this conversation to resolve such an issue.
I dont use BigPicture but I am not sure how setting remaining estimate to 0 helps in Reports, say Sprint Report.
@Abhishek , it helps if your board has 'tracking remaining estimate' option set..
Also, to reflect the reality that when the task is set to done, there is no remaining effort - this automation helps.
This link is not working anymore can some please provide the correct link
