Hello Team,
I am trying to find the all the Pre-installed gadgets help to understand the output and need to share with team.
I found some of the videos but this are scattered didn't find some proper guide line for to understand the gadget.
Please help me to share some link for the same.
Hi @Hitesh Prajapati Are you referring to Dashboard gadgets? Then this documentation article gives you more info.
Thanks for answer, I have refer the same but that article have only single line description for all the gadgets.
I required some guide line article for the understand the gadget so we can share with the team for the same.
Help me find the same. Thanks in advance.
There is no additional information available about these gadgets. I suggest you create a test dashboard and add these gadgets to see the available options for each gadget, then decide which gadgets are most useful on a dashboard.
Register now
