Prevent workflow transition with groovy script condition
Laurel Moczydlowski May 8, 2018
I'm trying to prevent a transition if a custom date field "Date for Removal" is not in the future. However everytime I do I get an error that says it can't find the custom field. I'm relatively new to Groovy so this is what I have thus far, any idea what I'm missing?
issue.getDateforRemoval < getDate()
Tarun Sapra
May 8, 2018 edited
You have to use the correct APIs, try this
import com.atlassian.jira.component.ComponentAccessor;
import java.util.Date;
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def dateForRemoval= customFieldManager.getCustomFieldObjectByName('Date for Removal');
def removalDateValue = issue.getCustomFieldValue(dateForRemoval) as Date
Laurel Moczydlowski May 8, 2018 edited
Thanks!  @Tarun Sapra
So to allow the transition if the date value is not the future it would be
Date <= getDate()
Or am I completely botching that?
Tarun Sapra
No it would be
Date now = new Date()
and then
removalDateValue > now
If removalDateValue is in future.
Adrián Plaza [DEISER]
May 8, 2018
Hi @Laurel Moczydlowski,
Can you share the complete script that is you using?
Adrián.
