Is it possible, using the scriptrunner plugin, to either block issues from being added to sprint if they've been in a sprint before and/or prevent sprint from starting if such issues are in planned sprint.
What I want to achieve is a particular type of ticket that throughout it's lifetime can be only in one sprint, and every new sprint will need to have a new ticket of that type created for itself.
I don't think that's possible.
At least I can't think of a way to achieve this.
There is nothing in script runner that would prevent manipulations from the backlog to drag issues to/front sprints.
The best you could do is generate some after-the-fact warning/notifications. Like check for such change taking place and either flagging the issue, adding a comment, or sending a custom notification to users/leaders/managers saying "hey you did something wrong here, don't do it again".
I assume same would be true for closing the sprint? ie. blocking sprint from closing if 2 issues of the same type for example are present in it?
Correct, that is my understanding as well.
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
