×I am using Xporter for jira docx template have a custom Text Field (multi-line) and i am looking for a string in it which starts with "DOC" and ends with "SRD" and was successful returning it via this code:
%{var match = '${Related Documents}'.match(/DOC-[^\n\r]*_SRD/); match ? match[0] : ''} |
However i am unable to find a solution to display the remaining text without the SRD string.
So in my example the ${Related Documents} value is
DOC123 Bla Bla Bla SRD
More Text
Some Extra Text
What i want to be able to print on my doc is:
More Text
Some Extra Text
Thanks in advance for your help
If you're willing to entertain a technology "shift" or "bolt-on", I may be able to help.
And no, I'm not trying to sell you another plugin, This is more of a "plug out"...
Our tool(s) uses Atlassian REST API calls to extract data through Power Query into Excel or Power BI. Once the data is in Excel, you can do any sort of "excel" thing to it you would like. That means text manipulation, substrings, and all the excel formula/pivot table things you like. You can also create versions of the Excel for stakeholders who want to be able to get a data referesh on demand.
However, it's been many years since I've tried to hook Excel and Word together. So if you're committed to your Word Templates and don't have the skills on board to create your word docs, then you may want to keep looking.
But if you want a simple spreadsheet or you want something more elaborate that you can create from a spreadsheet, let me know. Thanks.
