Good morning,
I know with the newly enhanced Jira Cloud, the ability to print cards has been done away with. Has anyone found a suitable workaround for this? I don't want to spend hundreds a month on a plugin, and the ones that I've looked at are pretty basic anyway,
We've tried exporting cards to Miro and printing there, but it's pretty clunky.
Any other tips, Friends?
Yeah, I just finally created my own .xls template and downloaded a CSV with the fields I wanted, then copy/pasted into the template. It's maybe a *little* clunky, but it gets the job done.
If anyone wants it, here's the link:
I don't know if there is a free solution for the problem, which also works for a single click (meaning that you don't pay with your time instead of your money).
You can use our app to produce a PDF like this (more samples) with one click from an arbitrary list of issues, which can be printed and then cut to physical cards:
You can customize the cards (add or remove fields, change the layout, remove the QR code, etc.) and even the paper. If you have a card printer, then you can print each issue to a separate page, so there is no need to cut anything...
(Discl. it is a paid and supported app developed by our team. Free for 10 users.)
A plugin to make this easier is probably what's required. When I've needed to do this myself, I've exported to .xls or .csv and then used my 20+ year old mail-merge skills in MS Word. :) It's a bit of a faff to set it up initially, but the process for subsequent print runs, is a lot easier.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
