Problem before upgrade to 8.22.6
David González
December 26, 2023
We have an error, and we are unable to access issues, it seems a problema with migration DDBB schema
Exception during health check invocation com.atlassian.jira.exception.DataAccessException: org.ofbiz.core.entity.GenericDataSourceException: SQL Exception while executing the following:SELECT pkey, issuenum, PROJECT, REPORTER, ASSIGNEE, CREATOR, issuetype, SUMMARY, DESCRIPTION, ENVIRONMENT, PRIORITY, RESOLUTION, issuestatus, CREATED, UPDATED, DUEDATE, RESOLUTIONDATE, VOTES, WATCHES, TIMEORIGINALESTIMATE, TIMEESTIMATE, TIMESPENT, WORKFLOW_ID, SECURITY, FIXFOR, COMPONENT, ARCHIVED, ARCHIVEDBY, ARCHIVEDDATE FROM jiraissue WHERE ID=? (Unknown column 'ARCHIVED' in 'field list')
Dan Breyen
Hi David, I'm no expert on Jira Server issue, but I found this when I googled your error:
/unknown-column-error-when-upgrading
That's for Confluence, but it might be related.
Hope that helps.
Nic Brough -Adaptavist-
December 26, 2023
That suggests your upgrade failed - the database has not been altered to match the new schema for the new version.
How did you do the upgrade?
SERVER
