Hello, I am trying to install Jira Server with Mac OS. I am getting the following message:
SYSTEM PLUGINS FAILED TO START: WE HAVEN'T BEEN ABLE TO START ALL THE REQUIRED SYSTEM PLUGINS
We couldn't start the following plugins:
com.atlassian.jira.jira-quick-edit-plugin (com.atlassian.jira.jira-quick-edit-plugin)
com.atlassian.jira.lookandfeel (com.atlassian.jira.lookandfeel)
What can I do to resolve this issue?
Thanks a lot.
Nelia
@Nelia Namur , you can disable all the add-ons from starting up so it can start the service properly.
https://confluence.atlassian.com/jirakb/add-on-tips-and-tricks-779168621.html
After you have logged in you can manually enable the add-ons.
@Nelia Namur Please use this KB article as a general guide from Atlassian to troubleshoot your JIRA start up issues due to plugins:
https://confluence.atlassian.com/jirakb/troubleshooting-jira-startup-failed-error-394464512.html
There may be several causes for this issue and this document will help you drill down to your specific cause.
Hope it helps !
@Nelia Namur Did my answer help you resolve your JIRA startup issue? If yes, please mark it as accepted for the others to follow.
