Problem with Text Field Search
Erik Cura June 5, 2023
According to this: Capture.PNG
The text field should search the summary section of an issue. In my usage I am finding that it is not properly doing that. There are many issues with the keyword in the summary that are not being presented with the text field search. Is this a known problem?
Trudy Claspill
Hello @Erik Cura
Can you provide an example of the keyword for which you are searching and the Summary field values that contain the keyword but are not showing up in your search results?
I have recreated the problem below with self made tickets:
These are all the tickets I have made. However when I search for the word "Avengers" in the contains text box this is all I get:
The only difference is that I put the word "avengers" in the description of Avengers-5. This search should display all 5 regardless of that since the summary field should have been searched also.
Trudy Claspill
June 5, 2023 edited
When using the text search the search mechanism is looking for free-standing words and stemming variations of those words.
Because you added a dash and additional characters (Avengers-5) to the word in the Summary, it has become a longer "word" that does not match the stemming variations of your search text.
To find issues where avengers is a stand-alone word or part of a larger string (as it is in your Summary) you will need to add a wildcard character (the asterisk) to the end of your search term.
Like • Balavinayagamoorthi Ramasamy likes this
I see. Thank you for your quick responses
Like • Trudy Claspill likes this
Erik Cura June 5, 2023 edited
I have moved my reply to the proper section
Read the story
