I'm trying to configure my Timesheet report to show an additional custom field but the dropdown only contains 1 field. Where are the rest of the fields? My underlying query contains the fields I wish to see in my Timesheet report but they are not available from the Timesheet Configuratiion page.
I've tried uninstalling and re-installing the plug in with no luck
I'm using Plug-in version 2.62 and Jira version 6.0
Hi Robert,
Weired, but what do you mean by 'my underlying query'? Would you please share screenshot to make sure we are on the same plate also?
Thank you.
Hi. This has been figured out:
I thought that by adding columns to my timesheet filter (Show summary for project or filter) I would be able to choose those columns from the Additional Fields drop down and then see them on my timesheet report. This was not the case. I had to go to Timesheet Plugin Configuration and choose the desired column from the Group by Fields drop down. Once the fields were chosen in the drop down I was able to go back to the gadget configuration and choose these fields from the Additional fields drop down.
Thanks.
Great, thank you for clarifying.
