×Hello everybody,
we made a upgrade from JIRA 6.4.12 to JIRA 7.1.
After the upgrade we get this header in our Gadgets.
http://fs5.directupload.net/images/160301/dxuyohak.jpg
How to fix this problem?
Sven
Hi Nic,
thx for your support..
We found the solution her
Sven
Could you check the log for errors when the dashboard is displayed? I suspect you'll find something i8n related as it looks like it's not reading the language files correctly.
It might be a config thing too, as I notice the third gadget is working. Do you get the problem if you add new copies of the same gadgets to the dashboard?
And can you confirm that the gadgets you have the issue with are the Atlassian ones built into JIRA and not coming from an add-on?
