Problem with my request
Equipe Support Squash September 9, 2024 edited
I encounter a problem when I run the request : Sprint in openSprint()
I have error messages :
The option provided by the ‘openSprints’ function for the ‘Sprint’ field does not exist. Several custom fields have the name ‘Sprint’. Try using one of the following terms: cf[10020], ‘Sprint[Dropdown]’.
And when I search in the custom field, I only have one Sprint field locked
Do you have any solution ?
Claire
Manon Soubies-Camy
Hi @Equipe Support Squash,
The screenshot shows that you're typing Sprint in Sprintactif() instead of the correct JQL function:
sprint in openSprints()
Even if your profile language is set to French, you need to type JQL functions as written in the documentation.
Hope this helps!
- Manon
Yes sorry i didn't send the good pictures because I test several ways of writing Sprint
Manon Soubies-Camy
Thanks for the additional screenshot! Can you confirm that you can see several different custom fields named "Sprint" in the administration? Looks like this is the issue. Since you also have a dropdown custom field named Sprint, Jira doesn't know which one to use in the query.
Can you try this JQL query instead:
cf[10020] in OpenSprints()
10020 is the id of the original Sprint custom field, the one created by Jira.
Unfortunately, I only see the one custom fields Sprint (on the second screenshot)
I already test with this JQL but I cannot understand why overnight the first request stop working
No new custom field with Sprint in the name was created
Manon Soubies-Camy
Do you have any team-managed projects?
I created a new dropdown field that I named "Sprint2" in a team-managed project, and it does not show up in the global Custom fields menu. I do see it in the global audit log though:
Could that be the issue?
When I searched i could find this one :2024-09-09_16h33_26.png
It could be the issue ?
Manon Soubies-Camy
Looks like it! You can try the following JQL query to understand which project this comes from:
"Sprint[Dropdown]" is not empty
Or just ask your colleagues if they remember who created it on that day :)
Unfortunately, no one remember creating it..
And don't know where I can run this request to find the custom field created
Manon Soubies-Camy
You can run it in the issue search, where you ran the "Sprint in openSprints()" one. It will only work if users filled out this field, though - if no one uses the new Sprint field, it won't return anything.
Do you have any ideas to find the ID of the Sprint[dropdown], rename it, or delete it?
or could also get an API to do it ?
Thank you very much for your help !
Manon Soubies-Camy
Sure, you can rename the custom field from the team-managed project's admin menu:
Hope this helps!
Equipe Support Squash September 10, 2024
Hello Manon !!
Thank you ! It's help me a lot !
It's now working !
Have a great day !
Like Manon Soubies-Camy likes this
Manon Soubies-Camy
Great, thanks for letting me know! :)
Jim Knepley - ReleaseTEAM
This question has come up before:
https://community.atlassian.com/t5/Jira-questions/Error-when-trying-to-use-openSprint-query/qaq-p/1171282
https://community.atlassian.com/t5/Jira-questions/JQL-openSprints-stopped-working/qaq-p/1208181
But your example query using the capitalized "Sprint" field looks correct. I wonder if there's some issue because you have a custom field named Sprint.
FREE
