Problem with the searching issues on text
Maciej Brachfogiel September 6, 2018
I don`t how can I serch issues:
I would like to find issues that in "Summary" begins with '[' then five numbers and then ']'
for example: '[12345]', '[00341]', etc
I tried to use something like that: \\[?????\\] or \\[*\\] but it dosn`t work :(
Can You help my or suggest something ? :)
Best regards
Maciej Brachfogiel
MoroSystems Support
September 6, 2018
Hi Maciej,
You can try:
Issues -> Search for Issues
You have the choice of Basic search (clik choise) or Advance search (by typing JQL). See documentation Searching for issues.
To search for any text use JQL:
summary ~ "\\[example\\]"
summary ~ "\\[12345\\]"
Best Regards
Pavel
MoroSystems Support
Thanks but I think we didn`t understand each other :)
Maybe I will give You an example:
I have a lot of issues with Summary starts like this: [11111], [22222], [33333], [other], SOMETHING
I would like to create a searching schema that allows me to find list of issues from example: [11111], [22222], [33333] (without: [other], SOMETHING)
I tried to use this:
summary ~ "\\[?????\\]"
 but it doesn`t gives me any results :(
MoroSystems Support
September 6, 2018
JQL does not have regex by default. But you can use ScriptRunner plugin and its JQL functions, for example:
https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html#_issuefieldmatch
Martin
MoroSystems Support
Maciej Brachfogiel September 10, 2018
Thanks !!!
I have to try it !!!
Maciek B.
MoroSystems Support
September 11, 2018
One more thing...there should be regular expressions by default in JQL in Jira 8, but there is no release date given for Jira 8 yet...
Martin
MoroSystems Support
In Advanced mode: summary ~ "\\[?????\\]" doesn`t gives any results
but for example summary ~ "\\[17449\\]" - works
