Problem with using Atlassian apps simultaneously
Davor
Is there a way to be logged in several Atlassian apps simultaneously.
Now we have problem that we cant be loog in JIRA and Bitbucket or Confluence in the same browser.
is there other way?
Aleks Yenin (Polontech)
April 18, 2016
Steve Behnke [DiscoverEquip.com]
April 18, 2016
It sounds like they are set up wrong. If you deployed them to the same host, you need to use Context Paths in order to get around your issue.
Davor
Ok, separate browsers will do the thing
