Hey Everyone!
I've been a Jira developer/admin for a few years now and have almost exclusively played with the UI, never the background server. So I figured I would use a spare home computer as a Jira server to play with.
I installed CentOS and PostgreSQL without issue. Since I'm not very familiar with server administration I ran the Jira default express install. When it finished it said that I could now connect via my web browser. Every time I try it tells me the server is refusing connections. I have confirmed that Jira is running and I can connect to the server with my terminal, but not via a browser. I'm seeing two errors that seem to pop up every time I start jira:
2018-01-15 22:50:58,120 localhost-startStop-1 ERROR [webwork.config.DefaultConfiguration] Skipping configuration for class 'com.atlassian.jira.config.webwork.JiraPluginsConfi
guration'
java.lang.IllegalStateException: Unable to resolve component: interface com.atlassian.plugin.event.PluginEventManager
at com.atlassian.jira.component.ComponentAccessorWorker.getComponentOfType(ComponentAccessorWorker.java:40)
at com.atlassian.jira.component.ComponentAccessor.getComponentOfType(ComponentAccessor.java:255)
at com.atlassian.jira.config.webwork.JiraPluginsConfiguration.getPluginEventManager(JiraPluginsConfiguration.java:85)
at com.atlassian.jira.config.webwork.JiraPluginsConfiguration$PluginSystemAccessor.<init>(JiraPluginsConfiguration.java:121)
at com.atlassian.jira.config.webwork.JiraPluginsConfiguration.<init>(JiraPluginsConfiguration.java:27)
... 3 filtered
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
at webwork.config.DefaultConfiguration.<init>(DefaultConfiguration.java:116)
at webwork.config.Configuration.getDefaultConfiguration(Configuration.java:135)
at webwork.config.Configuration.getConfiguration(Configuration.java:112)
at com.atlassian.jira.config.webwork.WebworkConfigurator.configureWebwork(WebworkConfigurator.java:66)
at com.atlassian.jira.config.webwork.WebworkConfigurator.setupConfiguration(WebworkConfigurator.java:59)
at com.atlassian.jira.startup.LauncherContextListener.initFastStuff(LauncherContextListener.java:137)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:101)
... 5 filtered
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalStateException
at java.util.Optional.orElseThrow(Optional.java:290)
at com.atlassian.jira.ComponentManager.getRequiredPicoContainer(ComponentManager.java:429)
at com.atlassian.jira.ComponentManager.getComponentInstanceOfType(ComponentManager.java:486)
at com.atlassian.jira.component.ComponentAccessorWorker.getComponentOfType(ComponentAccessorWorker.java:38)
... 25 more
and the other:
2018-01-15 23:20:56,263 localhost-startStop-2 ERROR [o.a.c.c.C.[Catalina].[localhost].[/]] Exception sending context destroyed event to listener instance of class com.atlassi
java.lang.NullPointerException
at com.atlassian.jira.startup.ClusteringLauncher.stop(ClusteringLauncher.java:46)
at com.atlassian.jira.startup.DefaultJiraLauncher.stop(DefaultJiraLauncher.java:197)
at com.atlassian.jira.startup.LauncherContextListener.contextDestroyed(LauncherContextListener.java:214)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4774)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5411)
... 3 filtered
Neither of those means anything to me (other than ERROR is bad), so any help you could provide would be awesome. Thanks!
Hi Ben,
Check that the ports are open and allowing connections from external traffic.
Thanks! I found an article on here that explained exactly what to do after you pointed me in the right direction.
Hi, Ben Could you please sent us the article link.
