Programmatically disabling scriptrunner Jobs, Listeners and Behaviours
Daniel Garcia June 4, 2023
How can I programmatically disable scriptrunner jobs, listeners and behaviours?
2 accepted
3 votes
Hi @Daniel Garcia
I assume you have many of these configurations and no direct approach to disable them in one go. But to answer your question. This is not doable.
You will have to disable your jobs, listeners and behaviours manually one by one.
You can, however, create an Improvement / New Feature Request via our support porta.
Thank you and Kind regards,
Ram
Daniel Garcia June 4, 2023 edited
Ken's approach below seems like a reasonable approach to me
Ken McClean
June 4, 2023 edited
Here's an example script I wrote that disables a ScriptRunner job. If you want to extend the functionality or get the specifics for your script, you'll need to watch the network traffic in your browser when you send a "stop" command to a listener, etc.  That'll give you what you need to rewrite the code
import com.atlassian.jira.config.properties.APKeys
import com.atlassian.sal.api.net.Response
import com.atlassian.sal.api.net.ResponseException
import com.atlassian.sal.api.net.ReturningResponseHandler
import com.atlassian.sal.api.net.TrustedRequest
import com.atlassian.sal.api.net.TrustedRequestFactory
import com.atlassian.sal.api.net.Request
import groovy.json.JsonSlurper
import groovyx.net.http.ContentType
import groovyx.net.http.URIBuilder
import java.net.URL;
import java.nio.file.Path;
def currentUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def baseUrl = ComponentAccessor.applicationProperties.getString(APKeys.JIRA_BASEURL)
def trustedRequestFactory = ComponentAccessor.getOSGiComponentInstanceOfType(TrustedRequestFactory)
def payload = ('{"@class":"com.onresolve.scriptrunner.scheduled.model.JiraCustomScheduledJobCommand","id":"a1c46fd2-0b69-4eeb-b955-8787a391db35","version":1,"ownedBy":null,"scheduleType":"CRON_EXPRESSION","disabled":true,"name":"Custom scheduled job","nextRunTime":1669391294170,"FIELD_USER_ID":"admin","FIELD_INTERVAL":"60","FIELD_NOTES":"Test job","FIELD_RUN_ONCE_DATE":null,"FIELD_JOB_CODE":{"script":"log.warn(\"this is a test job\")","scriptPath":null,"parameters":{}},"canned-script":"com.onresolve.scriptrunner.canned.jira.jobs.JiraCustomScheduledJob"}')
def endPointPath = '/rest/scriptrunner/latest/scheduled-jobs/com.onresolve.scriptrunner.canned.jira.jobs.JiraCustomScheduledJob'
def url = baseUrl + endPointPath
def request = trustedRequestFactory.createTrustedRequest(Request.MethodType.POST, url) as TrustedRequest
request.addTrustedTokenAuthentication(new URIBuilder(baseUrl).host, currentUser.name)
request.addHeader("Content-Type", ContentType.JSON.toString())
request.addHeader("X-Atlassian-Token", 'no-check')
request.setRequestBody(payload)
def response = request.executeAndReturn(new ReturningResponseHandler < Response, Object > () {
  Object handle(Response response) throws ResponseException {
if (response.statusCode != HttpURLConnection.HTTP_OK) {
   log.error "Received an error while posting to the rest api. StatusCode=$response.statusCode. Response Body: $response.responseBodyAsString"
   return null
} else {
   def jsonResp = new JsonSlurper().parseText(response.responseBodyAsString)
   log.warn("REST API reports success: $jsonResp")
   return jsonResp
Thanks, that is perfect
Radek Janata
I needed to disable jobs (when replicating production Jira environment to the testing one).
After the replication is done and before starting the new Jira on testing environment, I just run the following SQL update (MySQL):
UPDATE AO_4B00E6_STASH_SETTINGS SR
SET SR.SETTING = REPLACE(SR.SETTING, '"disabled":false', '"disabled":true')
WHERE SR.KEY = 'scheduled_jobs';
However, after Jira is started, all jobs seem to be disabled (greyed out) but they're still enabled. I have to go manually to Jobs, open and edit a job (just open and save) and all is OK. Not sure how to work around this.
Learn more
