Good time of the day, community.
Is there any Jira add-on or feature which can show progress of task in the list or somewhere else?
@Maruf Mamurov As far as I know you can add the original and remaining estimate, but not a progress/percentage bar.
However, there are some reports that may help you. You could check the "Time tracking report" or the "Version workload report" (some documentation: https://confluence.atlassian.com/jirasoftwarecloud/reporting-764478415.html ).
To have a more high-level view you can also have a look at the gadgets on the dashboard, "Jira Roadmap" for instance.
But it also depends on what you want to show to the management, is it about a print, a version or some issues in particular.
You can also try using Advanced roadmaps if that meets your requirement. The reference document is here - https://support.atlassian.com/jira-software-cloud/docs/track-progress-using-issue-count-in-advanced-roadmaps/
